TwinTurbo.NET: Nissan 300ZX forum - Only use a digital VOM. The throttle body difference >>>
Subject Only use a digital VOM. The throttle body difference >>>
Posted by ZUL8TR on January 10, 2013 at 8:57 AM
  This message has been viewed 229 times.
In Reply To Re: Even though new is it properly set? As noted above>> posted by Zeto32 on January 09, 2013 at 09:12 PM
Message needs to be adjusted (B4 the TPS is set) so they both close exactly the same as well as open the same. There is a section in the manual that tells how to adjust them. If you can't find the section let me know.
ZUL8TR in Orlando,FL
